I encoded a 58-min. video using TMPEng. It works great. I created chapters and burned an SVCD using Nero 5.5xx, it seemed to work fine but when I play it back on my computer's DVD, I cannot see the menus - though the playback is fine. Then when I try to play it back on a Sony DVD player, it does not recognize the disk at all. Any ideas why?
There is only one or 2 sony's that I have found that will play vcd's with any reliability let alone svcd's, I recently went out to stores with vcd and svcd test disks. I think I found one sony that would play svcd and it was very expensive, and maybe one other sony that would play the vcd. check the dvd player list here and see if your model is listed.
Well..all I can say is that you never know if your dvd-player can play svcd's or not. But if it plays vcd's it might also play svcd's. I got a Samsung 909, and on this page(vcdhelp) in the standalone dvd compatibility section is says that my player CAN'T play svcd's. I also thought so couse I tried to burn svcd's and my player recognized them as video cd 1.1 and the screen was black...no movie. But somehow I tried to burn a svcd with a program called Ulead MovieFactory and suddenly it worked...perfectly. NERO did'nt work but Moviefactory did. The two cd's I created are the same...but with NERO it didnt work...
So try burning with different author-programs.
I think your player can play svcd's. -
I forgot one thing.
Instead of using a "MPEG2" directory you have to use "MPEGAV" on the svcd.
let me know how this will work -
Hi,
I have the same problem with the samsung dvd-907 player. Loading SVCD...playing on the counter but nothing on screen ! I used to record with different softwares...Nero, DVDMovie Factory, VCD Easy... nothing works. On the compatibility page of this site is it quoted as working with SVCD'....please help
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 13:44 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 17:22 -
Cannot figure out which dvd player will work.
By capman21 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Mar 2008, 10:04 -
Film Don't Work On DVD Player...
By Chana1 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Jul 2007, 16:25
