I have used DvDit and use encore on a regular basis I have downloaded the trial for DvD producer and have no clue what to do with it does anyone know where to some training on this.
Okay, your post makes little sense. You mention 3 programs. Which program are you looking for a guide for? Also have you bothered to click on the little help file at the top of the program?
With the Demo, you should have the Help Menu, as well as I believe a Demo project / tutorial it installs to help get your feet wet.
While there are very few posted guides directly show you how to do what in Producer itself, the closest or most similar product would be DVD Maestro. There are guides for that here, or on doom9.net as well.
Your most helpful tools however will be the tutorial, and then a quick read on the manual. The main difference between DVDit and Producer is you now will have to prepare all your menu's / overlays yourself (as it is unlike DVDit with the built in library), and also it can take any combination of ES sources within a project - psd, m1v, m2v, ac3, pcm, etc, etc,...
I use DVD Menu Stuido for menu / overlay (psd) creation and the Producer for all authoring once all your sources are prepared and ready to roll.
Producer is an excellant authoring package, I highly recommend it~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Power Producer 3
By RED SHIFT1 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 00:15 -
Proshow Producer 3.2
By nace in forum Authoring (VCD/SVCD)Replies: 2Last Post: 13th Aug 2008, 01:29 -
Anyone know Power Producer (first version?) very well?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2008, 11:37 -
HD SlideShow using ProShow Producer
By zenzen1 in forum Newbie / General discussionsReplies: 3Last Post: 30th Oct 2007, 00:36 -
cyberlink power producer 3.0
By lennethe in forum Authoring (DVD)Replies: 3Last Post: 25th Aug 2007, 12:30
