I'm using the newest version of TSCV (from the TSCV website...which is diff. from the one on Doom9.org)and the EXTRO mpeg doesn't seem to want to play (I'm testing it on WinDVD). Are there specific sizes that this MPEG needs to be (aside from the normal SVCD standards - 480x480, etc).
Instead of playing that MPEG (a change CD logo), it just restarts from the begining playing the intro MPEG again.
Thanks for any help.
(Also, if anyone wants to answer - havent tested this yet - but can you use the direction keys on your DVD player to navigate SVCD menus made in TSCV or only the keypad? Thanks)
<font size=-1>[ This Message was edited by: Necromancyr on 2001-12-12 09:55:10 ]</font>
Have a look at the xml. Timeout of the last MPEG track should refer to Extro instead of Intro. Of cource you can use the direction keys as well as the number keys, if the SVCD is authored in the right way.
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 16:39 -
Mpeg Problems
By marbletravis in forum EditingReplies: 4Last Post: 23rd Jun 2008, 12:24 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
MPEG-2 Problems...
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 13:14 -
MPEG 2 problems
By specwarrior09 in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2007, 12:16
