  1. Member scottb721's Avatar
    Oct 2002
    Australia
    I created a DVD image using Shrink and then mounted it to a virtual drive using Alcohol 120%.
    When I browsed the drive with DVDdecrypter it said "Disc is not DVD" or words to that effect.
    Is this normal ?
    Alco120 was just reinstalled after loading XP SP2 last week.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Can I ask why you're trying to load it into DVDDecrypter after you've ripped/shrunk it ? What are you trying to do ?
    I know for sure that DVDDecrypter can only read optical drives unless you're in ISO Write mode, so I would assume that it detects (quite rightfully) that the mounted image is not a true DVD drive.
    If in doubt, Google it.
  3. Member scottb721's Avatar
    Oct 2002
    Australia
    I wanted to demux some vob streams and I already had the image mounted so I thought I'd just use that.
  4. burn it to a disc then rerip it,would be easier i think.
    LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
  5. Member scottb721's Avatar
    Oct 2002
    Australia
    That's what I ended up doing,
    Cheers
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    I've used Daemon Tools to mount a DVD ISO IMAGE FILE then open it up in DVD Decrypter.
    - John "FulciLives" Coleman
