I've had 2 occasions now where menu's don't work on the copied version.
Both times the disc was done using DVDShrink and burnt with Decrypter.
1st case - Dirty Dancing - The menu for the song film clips had now overlay so you couldn't choose an item.
2nd case - The Incredibles - Disc 2 menu had no overlay so nothing could be selected.
Anyone else seen this sort of thing or know why it might be happening ?
I noticed that with Incredibles disc 2. You can pick each item by pressing 'down' on your remote, one press at a time and follow the invisible curser in your mind to the item you want , then press enter.
Or use the 'play all' which is the first item on the list and the invisible curser should be on that at the start.Why is it doing that? -
I redid it using Decrypter and CloneDVD2 and it worked fine.
I haven't reattempted it yet with Shrink to see if I can reproduce it.
Any ideas what's going on ?
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 07:44 -
srt subtitles don't display properly
By briligg in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2009, 13:12 -
Backup DVD can't be read normally, menus don't work
By chtit_draco in forum DVD RippingReplies: 7Last Post: 18th Apr 2009, 09:30 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
dvd movies don't screen on monitor properly are split into 3 sections
By beachychick in forum Software PlayingReplies: 3Last Post: 29th Oct 2007, 19:03
