    Jan 2003
    Brazil
    Doeas any of you know a software that let us make menus there are something like a video that the buttons and or links just appear at the end of those videos?
    Apr 2004
    Miskatonic U
    Huh ?
    A clearer explanation of your requirements might get you an answer.
    Read my blog here.
    Jan 2003
    Brazil
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    I'm not sure I understand your question. But I think you're asking if you can author a DVD to automatically play the movie when it's inserted, and then give you a menu when the movie is complete. If that is what you want then it should be a simple process for any authoring software. In TMPGEnc DVD Author, you would set Firstplay Action to "Play All Tracks" or "Play First Track Only"
    Buy My Books
    Jan 2003
    Brazil
    No no no. That's not what I am talking about. I am talking about a kind of motion menu, but the difference, is that the menu is played just once, and the buttons and the links just appears at the end of it. How could we make one of those?
  6. DVD lab Pro has that,I think they call it "Button Delay".
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    <stab in the dark>
    Sorta like an "intro" clip is played on insert, then the menu appears at the end of it ?
    I think you need to look at rewriting / rephrasing your question
    If in doubt, Google it.
  8. In DLP, set firstplay to your intro, then endlink it to the first menu.
    Cheers, Jim
    My DVDLab Guides
