Hello everyone. I burn VCDs using Nero and for some reason when I play them they are a bit messed up. The sound is synced with the video but sometimes the frame will freeze for 2-3 seconds every now and then but the audio keeps going while its frozen. I know thats its not the media I'm using and I know that its not the mpeg file, it has to be something in the burning process. I tried switching from "disc-at-once" to "track-at-once" but it still does the freezing thing. Any help would be appreciated.
Originally Posted by Znooky
Thanks i'll check out VCDEasy.
Originally Posted by marco_the_boy
I was using TMPGENC also. I didn't check to see if it plays like that on my computer but it does that on my standalone (Toshiba SD2800). Thats interesting, i'll have to try another encoder. Can you recommend a better one? Does VCDEasy encode to mpg for sources such as divx and xvid? -
This problem only happened on a Cyberhome DVD player viewing TMPGENC VCDs.
I then used Mainconcept to encode VCDs. The quality was just as good if not better and the encoding time was much faster.
The problem did not happen when viewing TMPGENC encoded SVCDs or DVDs on the Cyberhome.
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 22:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 10:57 -
Freezing & skipping issue during playback
By Zumeraga in forum Video Streaming DownloadingReplies: 2Last Post: 4th Dec 2010, 18:55 -
La Cinema Classic HD Freezing issue.
By Kyluke in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 06:36 -
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55
or just this one you are trying to burn? I have burned VCD
