Hello,
Just went over to the xbox forums to post a question about my buggy wireless router. The tech forum is moderated there and requires a "REVIEW" before its posted! WTF???? I thought the whole point of forums was for rapid feedback????
I mean thats crazy. Waiting for it to be ok'd????
Kevin
Results 1 to 15 of 15
Is that just for the first post or for every single one?
What's your problem
I'll try to see if I can help
You can run into some goofy people in lots of forums
I just reread a reveiw? I havent posted there in a while but I didnt know that -
Hello,
Well I can't get the adapter to recognise the dns server. Someone mentioned resetting the wireless router to the factory defaults to fix the problem. But I really would hate to reset everything on it.
And shadowmistress - I don't really know. It just said that the tech forum had to review every new thread before posting.
Don't you have a laptop with ethernet? Try hooking the laptop up to the gaming adapter and seeing if net access works for you. If it works for the laptop it should work for the XBOX. If it doesn't then something needs to be reconfigured.
Nothing can stop me now, 'cause I don't care anymore. -
Hello,
Nope - just a wifi card for the laptop. Besides thats a P2 that hasn't been configured properly for my wireless router.
I'll figure it out again eventually. It just sucks that I can go on LIVE for weeks at a time and then I have to fight it to get it back on......
Who makes your router?
Hello,
Its a DLINK DI 524 G router.
Kevin
(its XBOX compatible
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you're worried about settings, I BELIEVE (don't quote me because I use mostly Linksys) that somewhere in the router config there's an option to BACK UP to a file. That way if you screw something up, you can just restore the config and you haven't lost anything. You gotta tinker a little bit, that's what computers are for. :P
Hello,
Well I went ahead and did the reset. NO LUCK!!! :P
Man I hate this wireless crap. When I can get it to work its flawless. It's the other 50% of the time that it fucks up.....
Oh well.....
Kevin
EDIT - By the way -they finally posted my thread at the xbox forum so I'll see what happens....Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hello,
How do I set up a direct connect for my xbox???
Isn't there some way to assign it its own IP and stuff????? I'd love to be able to just set it once and forget about.
Can I tell it where my router is and all the info with out it doing an auto check?????
Hello,
I thought of something - would an AD HOC setup be more reliable??????
No, you want Infrastructure, not As Hoc. Ad hoc is between wirless devices where an access point (or wireless router) is not part of the network. I'm not 100% certain, but I think the XBOX has it's own IP already, I don't think it uses DHCP.
I can understand each post being reviewed. This would be to prevent people asking for warez, or discussing anything illiegal.Originally Posted by yoda313
However, i can see the disadvantage of it. It kinda sucks if you need a instant reply or your question is of urgency.
It means more work for the moderators, just imagine the time it would take to review each post individually considering the amont of posts made per day. Thats gonna take a while.
You never know, you could be waiting for a couple of months till its your turn for your post to be reviewed :P :P :P -
Hello,
I'm back on XBOX LIVE! For now anyways......
I'm not entirely sure what I did. All I know is I'm not going to change any settings at all for awhile. Hopefully I won't need to....
Thanks for any help you gave
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Live Video Mixing with Flash Media Live Encoder
By fuggles7 in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2012, 14:08 -
How to broadcast a live satellite TV by Adobe Flash Media Live Encoder
By mrweb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2010, 21:08 -
Where do you live?
By johns0 in forum PollsReplies: 29Last Post: 27th Jul 2010, 14:54 -
How to stream live mms click from one mobile to another mobile live
By rahul1971 in forum Video Streaming DownloadingReplies: 0Last Post: 19th Mar 2010, 07:14 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03
