What is the easiest way (if there is) to convert WMV files to Divx/Xvid so I can play them in my Phillips Stand Alone player?? Thanks all!
Either use Video Edit Magic (pay software) which will handle WMV files or TMPGEnc (free).
Don't open file with TMPGEnc but rather drag and drop the WMV file into the preview window.
Click File > Output To File > AVI
and choose
DivX or XviD Video Compression
MP3 CBR audio compression -
Ok I did a conversion with Tmpg. Seemed to go smoothly. When I go to play my new divx file i get a message that says This avi file was not prepared for sequential reading, the alternative AVI splitter will now let the default one handle it. The complete reinterleaving of this file is strongly recommended before burning it onto a slow media like a cd-rom" After I close that, the file plays fine. But why am I getting this? Wrong setting during conversion? Also will this affect the ability to play on my stand alone player? Thanks!
Originally Posted by glenn71x
I just used the default settings in TMPGEnc and the DivX 3.11 codec. When I had the DivX 5 codec and XviD installed at the same time, I had alot of problems.
I would burn it onto a cd-rw disk and see if it plays. If it doesn't, you can erase it and try again. You might try direct stream copying it through Virtualdub also and see if you get any error messages.
WMV to Xvid or Divx
By glenn71x in forum Video ConversionReplies: 3Last Post: 15th Jul 2009, 15:27 -
Multiple .wmv to single Divx
By Techsysman in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 08:56 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
Fast Divx to WMV Converter?
By Tchail in forum Video ConversionReplies: 5Last Post: 10th Dec 2007, 13:19 -
PocketDivxEncoder0.3.96 will convert WMV to DIVX
By draven1968 in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 11:46
