    Dec 2001
    India (living in US)
    Hello all
    I am sort of new to this. I was trying to cut a mpg file into two parts using TMPGEnc (as is given in http://www.vcdhelp.com/tmpgencedit.htm).
    After these steps:
    1. Drag the bar to where the clip should start
    2. Hit Start
    3. Drag the bar to where the clip should end
    4. Hit End
    5. OK
    As soon as I hit 'OK', the following error message pops up: "At address 73F91D04, Read error occured against address 73F91D04."
    Can someone kindly tell me how to fix this?
    Thanks a ton!
    ~Sri~
    Feb 2001
    Palmdale, CA
    Ignor it, it is a bug that doesn't matter, your cut will be fine.
  3. Use MyFlix it's easier and better
  4. as sommersby says in the post below a couple of fellas state the solution to this problem is to just press OK when the error appears.
    sadly this couldn't help me since the program shuts down after the error shows so no way to press "run" after "ok" in the error msg...reason why I'm now downloading MyFlix
    https://www.videohelp.com/phpBB/viewtopic.php?topic=68464&forum=4
