  1. I have found the following issues that need to be resolved.
    1. There is no way to remove a title set other that to close and re-open the program.
    2. If you try and author a DVD with 2 titlesets one of which is empty, the program crashes with an exception error.
    3. If you were working on a project with more that 1 titleset and start a new project by hitting the project button, all the title sets remain and are blank. I think that only 1 title set should remain here.
    Thanks for a great program...
    Harry.
  2. Hi Chris i can Confirm items 2 and 3 theres is a problem see Screen shot and log file i emailed you
    1. There is no way to remove a title set other that to close and re-open the program. (Try Draging into recycle bin )
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. Thanks for the headsup guys. I have these bugs fixed now and the fixes will be in the next release.
    CB
