Hi just want to now if there´s any program that joins 2 Avi´s and Subtitles at same time??
I join 2 Avi´s with virtualdub and the subtitles with Subtitle Tool,but now they don´t match![]()
Tanks![]()
If you use AviSynth to join the videos in VDub, then note stretch or shrink the lengths of the subtitles with Subtitle Tool to synch them to the time given to you by VDub, you should be okay.
Try Subtitle workshop to join and make sure you do it before getting rid of a least the first avi as it needs it to get the correct length for adjusting the starting times in the second sub file.
Subtitles problem !
By mathbes in forum Blu-ray RippingReplies: 1Last Post: 17th Sep 2011, 17:39 -
Another Subtitles Problem
By Djanarak in forum Video ConversionReplies: 4Last Post: 5th Jun 2011, 06:30 -
Problem with subtitles
By romanvida in forum Authoring (DVD)Replies: 1Last Post: 4th Oct 2010, 15:38 -
Problem to swap one subtitles to another
By mangus37 in forum SubtitleReplies: 7Last Post: 2nd May 2010, 04:52 -
Problem with the subtitles
By empana in forum SubtitleReplies: 2Last Post: 11th Nov 2008, 05:54
