i'm having trouble installing huffyuv. would anyone out there know a way to fix things? i unzipped the zip file, and right-clicked on the huffyuv.inf file, and clicked on 'install'. It looked as though it completed, but didn't. any suggestions? how would i uninstall it, and then install it again?
thanks
Generally if you just try installing it again it will overwrite the bad install.
However if you need to uninstall it, normally you should see an uninstall option for huffy in the 'Control Panel' -> 'Add/Remove Programs' list.
For Windows 98 you can also remove it by going to 'Control Panel' -> 'Multimedia Properties' -> 'Devices' -> 'Video Compression Codecs', select the 'Huffyuv' codec and click on 'Properties' and you should see a 'Remove' option.
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 07:31 -
HuffYUV Question.....
By vipin in forum Video ConversionReplies: 7Last Post: 7th May 2010, 13:36 -
H.264 to HuffYUV
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 4th Apr 2008, 01:25 -
capturing to huffyuv
By nagihcim1 in forum Newbie / General discussionsReplies: 9Last Post: 4th Sep 2007, 21:07 -
is it possible to compress HUFFYUV?
By Lee82 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2007, 13:56
