whenever i convert any video file with EO, the comverted file is always much larger than the original file:
eg: orginal - 699mb
after conversion - 22 GB
could someone tell me how to fix this problem? Any help would be much appreciated....Thanks in advance
wat format are you converting to?
your converting something which is a divx or xvid (avi) into an uncompressed avi
why would you do that
the 699mb avi (of questionable source) will fit on a cd
if you want to play back on a dvd player convert to mpeg2 using an encoder like tmpeg or tmpgenc express
if you want to cut say the credits off the end or just a chunk out of it
http://nickyguides.digital-digest.com/join-split-avi.htm
people really need to know exactly what you want to do before it is possible to give advice -
rmvb is similar to Divx and Xvid. Try Xvid in quantization mode with a Q setting around 3 or 4. Remember the audio too -- you'll probably want MP2 or MP3.
Do 2 passes with the same bitrate as the original rmvb file and you will get the same size, plus or minus the difference in overheads.
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 05:23 -
decrease file size
By zsuppguy in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2010, 17:30 -
How could I decrease video file size but keep high-quality?
By jace89 in forum Software PlayingReplies: 11Last Post: 20th Dec 2008, 21:25 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 12:51 -
Decrease size of dvd
By haris in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 13:58
