I am trying to burn a fujifil DVD-RW with pioneer 109, firmware 1.17, on panther using toast titanium 6.0. I used the DVD-ROM UDF option..
the problem is it never finishes writing "lead out" and the light on the burner stays on. I had to force shutdown the computer to get it to stop. What the heck is wrong.
Some things to look into.
-Make sure Toast is updated to 6.0.9
-Writing lead-out is a surprisingly long process. So be advised
-Take a look here for info on how to update your drive's firmware. The 109 is up to 1.40. I don't think Flashit or the newer DVRflashX are compatible with the 109 yet, but there is some information on how to flash them using VirtualPC.
http://forum.rpc1.org/viewforum.php?f=30
Alph -
I might have spoke too soon. I left it on, and your right its a surprisingly long process. It took only about a minute for dvd-r. It took 6 minutes with a rw. So im relieved that it worked. Thanks for the update info. I used to have VPC but i have no darn space on my HD to install it anymore getting an HD soon
Problem with recording apps hanging after sitting idle under XP Pro.
By brassplyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2011, 07:22 -
Help!! Recorder hanging.
By mthomas90 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Aug 2010, 10:51 -
Ripbot264 hanging
By ma2kp in forum Blu-ray RippingReplies: 7Last Post: 13th Nov 2008, 09:59 -
dvd flick - hanging on audio encode
By ducky12 in forum Newbie / General discussionsReplies: 1Last Post: 11th Nov 2008, 02:50 -
Premiere CS2 hanging during simple tasks
By Schwez in forum EditingReplies: 2Last Post: 4th Oct 2008, 16:17
