umm.. I have a .jpg picture with two buttons drawn on it. i.e. movie #1 and movie #2.. I was goingto try and use this one. I think I can do it in Sonic MyDVD?
yep, that's all I really want to do jimmalenko...
remove menu + extras from both DVD's and put onto one single dvd with my own .jpg menu...
I used DVDShrink on both movies and they are both in there own folders on my harddrive. I have taken everything away apart from the movie itself.. I thought I could use MyDVD, add my menu and just "get" the movies.. but NO
TMPGEnc DVD Author would be my tool of choice for this. Load each VIDEO_TS folder in as a separate track, then specify your JPG as the background for your main menu.
If in doubt, Google it.
