hi, doing my first backup with rebuilder, and after 4 hours on the 1 click setting get this error pop up,
Error: File *********** shows completed, but no .M2V file exists.
any ideas ??
using cce btw
clicked on the ok, and its carried on with the job......
yet to view the output files as the encode is still in progress.......
Results 1 to 30 of 39
Had problems myself with all versions of DVD-Rebuilder even tried to upgrade to 0.80.
I'm using Cinema Craft Encoder also and always had problems in the rebuilding stage ( i never used the one-click solution ). Then i found somewhere in a forum ( I can't remeber where ) that CCE had problems encoding 1 frame AVS. So i went through all my files created by DVD-Rebuilder and re-run the ones with only one frame in TMPGEnc. After that the rebuilding stage was fine and I got a perfect backup of my movie.
Good Luck -
Tried using version 0.80, and when the encode got to 70.2% i got the same error code.......
I really want this programme to work !!
Anymore idea's
TIA -
Updated to professional v0.83, guess what, same error, after 32% this time.....
i updated as this version was supposed to address possible reasons for this error.....
come on you experts out there......
TIA -
Update.
Well, i decided to try a differant movie rip before i went to bed last night
and was confronted with this error code...
DVD Rebuilder experianced a buffer overflow. Error #0003. process must abort
Well at least it got past the encode this time........
Any idea's now ?? -
I cant help you but I ran into the same errors. I havent had a successful burn with this software yet.
Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall -
Most of the problems of Rebuilder are there because of bad configurations.
Use my installer, available at www.dvdrebuilder.com
... by the way... CCE (versions) 2.70 have some serious bugs... if you run into probems, use one of the free encoders or use versions (CCE) 2.50 or 2.66/2.67.
keep it UPMy oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
@djblade
What can I say... more than 20.000 users use it... one that had problems with it (you)... not a bad average, don't you think?
DVD Rebuilder
Update.
Just tried a movie only re-encode, and failed again at the rebuild stage, error 003, buffer....
keep your ideas coming, i wanna crack this..... -
Well... use the installer
Don't make any pre-process with the source.
In extreme cases use the option "Special Error Processing" under Options Menu... note: just in extreme cases of error 3 and 4 on Rebuild phase... if it works... don't forget to unselect it again.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
It take you a week to make the backup?!?!?!
Are you including the "problem" days?
DVD Rebuilder
I had all kinds of problems with DVD Rebuilder until I used the installer and since then I've had no problems at all.
NEC ND3500A/G
Unproper and proud of it -
I'm now making STUNNING backups with DVD Rebuilder/CCE
Thanks all for your input..... -
Now we're talking
DVD Rebuilder
I am having the same error with "M2V file exists"
tried using two different versions of CCE SP.. 2.5 and the latest.
I am also using the latest build of the pro version with my $10 donation thank you...
I just downloaded the installer for the free version... (haven't tried it yet) is there an installer for pro version... and what is the big difference anyways between the two? -
There will be an Installer for the PRO version (maybe today).
What do you mean? differences between installers or the Rebuilder versions?and what is the big difference anyways between the two?
If you are referring to the Installer... my advice is to wait... it IS different.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
I have been trying to mess with this software for like 2 days straight... I can't for the life of me get it to work with CCE...
The "M2V file exists" error pops up with the freeware installer and I am lost now... I want to use CCE with this considering all the hype I read about the results.
I am doing a test with the Star Wars Empire Strikes Back.
I did one in DVD Shrink, Nero Recode 2, and now I am trying to use DVD Rebuilder with CCE to see the difference. -
They all turned out bad IMO, I just put it on to 2 discs with full menusOriginally Posted by low-fat-al
Once again I say... I have been trying to mess with this software for like 2 days straight... I can't for the life of me get it to work with CCE...
anyone .. anyone ..? -
Did you use the installer version or the manual version of RB?Originally Posted by low-fat-al
What version of CCE?
Is this version liciensed, demo, demo hacked, pro hacked?
BD Rebuilder error help
By JBIRD316 in forum Blu-ray RippingReplies: 1Last Post: 18th Apr 2010, 06:57 -
BD ReBuilder error
By titot4u in forum Blu-ray RippingReplies: 30Last Post: 29th Jan 2010, 17:44 -
BD Rebuilder error
By wthldh in forum Blu-ray RippingReplies: 3Last Post: 12th Jan 2010, 19:42 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 15:39 -
BD Rebuilder Error
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 28th Dec 2008, 11:16
