I have the pioneer 220 and when I try to record a program on "spike" tv I get a some color distortion or a picture that is different from when I dont use the recorder as a tv tuner. Does "spike tv" output a signal that my dvd recorder does not like? I have been trying to record the "ultimate fighter" program. Anybody know anything about this or if there is a way around it?
thanks
The dvr-220 will display a message stating that the material was copy-protected, and it could not record. So that should not be the problem.
Are you using a cable box or splitters or anything that might degrade the signal quality? -
Yeah, I am using a splitter. It looks like I just have problems with that specific channel. I do not get any message saying that the material is copyrighted so it must be my bad cable reception then. Maybe it is time for satellite.
I noticed on a Philips DVDR75 that it will try and punch up a weak signal, screws with recording old tapes, resolved that by putting a color burst amplifier inline and tweaking it up manually and the philips stopped doing that. Maybe same thing?
Hello Colt,
Put that recorded DVD-RW into a DVD Player. Select your quality of DVD and record your final movie if you have Macrovison hack. Hopes it work --- if not ---sorry --- don't kill the messenger.
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 14:42 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24 -
DVR card BNC Female to regular cable (rg60) conversion
By johnnyfly123 in forum Capturing and VCRReplies: 1Last Post: 27th Mar 2010, 16:49 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 15:50
