I have found a brand of DVD-R that works just fine when backing up commercial dvd movies using apps such as Shrink, DVD-lab and DVDFab.
But lateley have found that dowloading movies that, at least some have had like 2-6 passes with CCE, while they burn and play fine at first they seem to be very hot and after a while errors start showing up as in stuttering/freezing. And if it goes on to far then CRC errors develop.
So........whats this about and is there anything to be done......I've trired reparing some of these by burning them with Shrink and this seems to help but they're still heating up and with one movie i got half way through it before it started to stutter and freeze!
This is a real pain not mention a waste of time if it can't be rectified!
comments/feedback?
thx
odwoh
Sounds like the brand of discs that you say 'work just fine' don't work well at all. Please update your profile with your computer/burner specs. Also, what discs are you using?
Comments on JVC BR-S525U
By daave in forum RestorationReplies: 0Last Post: 4th Apr 2011, 01:59 -
Advice - Comments - my setup - and use
By channelk in forum Newbie / General discussionsReplies: 0Last Post: 3rd Feb 2011, 15:28 -
E3 2010 - favorites? comments?
By yoda313 in forum Off topicReplies: 2Last Post: 20th Jun 2010, 20:16 -
IE 8 comments
By stiltman in forum ComputerReplies: 31Last Post: 29th Mar 2009, 06:02 -
More or less intelligent comments
By Photogregor in forum Newbie / General discussionsReplies: 22Last Post: 1st Nov 2008, 04:30
