Results 1 to 13 of 13
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone,
    i wanted to make a multisession VIDEO DVD, can anyone tell me how?
    Wow! You got shocks, pegs... LUCKY!
  2. Why do you want multisession?
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    well, i want to do a series of tests, and, call me cheap, but i dont like wasting media...
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Then use RW.
    Kevin
    Just burn your project - test it out - then rewrite. Simple and easy.
  5. DVD video can't be multisession.
    Use DVD-RW.
  6. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i know that would be the SMART thing to do, but i simply dont have enought time to shedule a day to go out to buy RWs...
  7. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Buy online then. You can get them anywhere.
    Kevin
  8. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    not a bad idea, ok then just for the hell of it, how do i make a multisession DVD...:P
  9. Select data and burn multisession,open(not finalized).
    You can't burn multiple VIDEO_TS folders because Windows and your DVD player will give an error or only play the first session.
  10. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok so how will i be able to make a multisession DVD that i can play whichever session i want...?
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Everyone it telling you the same thing - you can't. Buy an RW, or create all your tests and compile them into a single DVD for playback. And I'm sorry, but "but i simply dont have enought time to shedule a day to go out to buy RWs... " is just so much BS.
    Read my blog here.
    Mar 2003
    Kansas City MO
    Gee - suss, is this person thick or what. The disk has to be closed out or it won't play. No you can't burn multisession. Yes if compling data. No time. Too bad, I guess no time to learn either. Learn to read and you won't be asking the same question over.
  13. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok thanks...
