http://s32.yousendit.com/d.aspx?id=2XKFDXRU3ZJQA2C84W3XKFBMTR
http://s32.yousendit.com/d.aspx?id=29DAKKIZDAGT71J20RLIZD7VMP
Top are links to examples of my menus.
My problem is that, I can't seem to add music files into the menu properly
The ac3 file always gets cut off at the beginning and replays Help!
edit: forgot to mention, i'm using DVD-lab pro.
The delay at the beginning is your decoder syncing to the signal. The length of time this takes varies from decoder to decoder. You can hide it by fading your audio in to beat the gap.
There is little point downloading your video, however a couple of screenshots of the project might help. Specifically the menu screens.
If you don't want it to repeat, make sure that it runs the same length as the video on the menu, and that you set the duration to the same length as the video. Duration is found on the PBC tab. By default this is set to 'inf', so it repeats indefinately.Read my blog here.
If you use Vegas and DVD Architect, you can fix this....even though it's going to take sometime. Drop your video file in Vegas. Open the audio - make sure both files have the same size. Encode the audio file as AC-3 with Vegas (it has a built-in Dolby Certified AC-3 plug-in). Open both files with DVD Architect (same name for both). This application has a timeline too, so if the encoded video file is a little bigger or smaller than the final AC-3, you can set fade points so the video file will match AC-3 file perfectly.Note: Vegas and DVD Architect are not freeware but you can download both trial versions.
Cheers! -
He? Who?
Now, please, how are you preparing those files (assets)? I mean, did you render them first with a NLE - non linear editor (example: AC-3 and MPEG2), or you're just preparing them with DVD Lab (organizing menus, audio files, text, etc)? Is that what you mean for preparing your files? -
The clips are about 10s each and the ac3 is over a minute, if i want to add audio to the menu, i have to cut the audio to the length of the video?
The audio is ac3 and the short clips are taken out of mpv files, both imported into dvd-lab. I dont' want to spend anymore money on this, so is there no other way other than cutting the length of the audio? There wouldn't be much of a song if its only 10s long.
Thanks. -
Make your audio and video assets the same length. If that means making your video assets longer, even by adding a still to make the balance, then that is what you have to do. That is how it is. You can't change the fact, so live with it and move on.
Read my blog here.
- for the original files? Yes....
-Hmmmm, I've tried this and the outcome was not acceptable.
Anyway, why don;t you recompress everything once again and then tell us what happens...
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 15:32 -
How Do I Add Music?
By Joshua P in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2011, 22:38 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01
