I am interested in combining two different dvd's with only 4 episodes on each, so Instead of using shrink for each separate dvd when theres still much more space on the dvd, I was wondering if it is possible to combine two, or maybe even three different dvd's together? And If I do this, what will happen to the menus on each separate dvd? It'd be sweet if I could keep the menus together as well, but Ill take what I can get, so all help and advice would be appreciated.
Thanks,
Dain
[img]vba02cbbfe6.gif[/img]
DVDRemake Pro can merge DVDs, and it will insert a higher-level menu, so you get a menu to select between the three DVDs' menus, keeping them fully intact and functional.
If in doubt, Google it. -
Aaaaah Thank-you sir, that's just the program I was looking for, and it allows me to choose between the different menus! Awesome,
Thanks,
Dain[img]vba02cbbfe6.gif[/img]
Combining DVD's
By grandsire02 in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2012, 07:06 -
Combining DVD ISOs
By TheLaserdisc in forum Authoring (DVD)Replies: 0Last Post: 19th Jul 2011, 21:39 -
Combining Mini-DVDs into 1 DVD
By Jinga in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2010, 11:06 -
Combining dvd clips to one file
By wtcamb in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2009, 12:51 -
Combining 2 DVD's help
By rede96 in forum Newbie / General discussionsReplies: 2Last Post: 30th Nov 2009, 14:35
