Hi everyone,
I have a small form factor PC, using SATA HDD for the first time. Does anyone know how to configure the HDDs and the DVD drive, if I have only one SATA HDD, and the second HDD and the DVD drive are both PATA? It's an Intel865 chipset with ICH5, which I'm told is one controller for both the SATA and PATA devices; and that I need to check the master/slave settings to make sure the devices are not in conflicts with each other. However, if I have both SATA and PATA devices in the system, the SATA is automatically bumped down to secondary drive (which means SATA won't boot first.) But since the SATA HDD is the OS drive (Win2K), am I supposed to set the SATA HDD as master, and the PATA HDD & DVD as slaves? Or because the SATA HDD will not boot first, I need to set the PATA HDD as master, the other devices as slaves?
This is my first SFF PC, and since the three devices each have its own connectors and cables, I thought they all could be left as masters. Wrong, I guess.
Hope my questions make sense. Thanks in advance...
Spiffy
There should be a bios setting to tell your SFF to boot from SATA.
SATA doesn't have primary or secondary in the same way PATA does.
On the IDE controller, set your PATA hard drive to primary(master) via the jumper pins on the drive, and the CD ROM drive to secondary (slave) via the jumper pins on the back of it.
sata HDD and IDE hdd
By rubberman in forum ComputerReplies: 22Last Post: 9th Mar 2011, 22:02 -
The Greedy Man, IDE & SATA, A Confused Combo
By Tom Saurus in forum ComputerReplies: 23Last Post: 10th Jun 2010, 00:36 -
XP / HDD / Sata Drivers
By themaster1 in forum ComputerReplies: 9Last Post: 15th Nov 2009, 18:52 -
evolving my hardware...pata + sata?
By bgd73 in forum ComputerReplies: 8Last Post: 1st Apr 2008, 12:37 -
ide dvd burner and sata harddrive - how do i configure?
By mshuang in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Dec 2007, 01:46
