Hi, I'm very new at this, as some of you may already know. Here's the story so far:
I have downloaded many a divx movie. I downloaded SVCD2DVD and DIVX2DVD and have successfully converted my .avi movie into an MPEG DVD file. The output file contains the Video_TS and Audio_TS folders like it should, the former having all the necessary files with those wierd extensions.
When I use SVCD2DVD to actually write the CD, I open my Video_TS file and try to burn it onto my 'Maxell 8x 4.7GB DVD-R' DVDs. I get an error message saying, "Please insert writable media". But it IS a writeable media! Does it not say DVD-R on the disc itself?!
My questions are many, but I'll summarize. One: Do I have to 'encode' the DVD before I can write something to it? Its obviously not working now. Two: Do I have to go through all those steps I've read about...like authoring the chapters, or dictating all the petty details in burning the DVD, when I just want to test this out to see if it'll work? All I wanna do is get video on my DVD disc from my computer! I feel there are some integral steps and concepts I'm not getting.
I want to say thanks in advance guys...without you I'd be wallowing in self-pity by now (moreso). If you absolutely HAVE to, refer me to another newbie guide (I've read a lot of them). On the other hand, some empathy would be very appreciated, or even better, some thought-out analysis of exactly what it is I'm doing wrong, or not doing at all!
Try burning the files with copy to dvd, dvd decrypter, or nero standalone versions. If that doesn't work, try another dvd. You may have a bad one there. I usually use dvd decypter in the burning settings with the "don't burn - just create iso" option selected and then burn the iso file later when I'm ready.
Thanks for all the responses, guys. To clarify: I meant to say "When I actually try to write the DVD", not CD. I have a CD/DVD-RW drive. My writing program is CopyToDVD. The file I am trying to burn to a DVD is around 1GB. My DVD-RW drive writes at 16x. I don't know anything about .iso or .cue files, but some have mentioned them while discussing DVD burning. What is their significance?
