I encoded a 3ivx movie file (dont worry, its not copyrighted) into ffmpegx (latest version) , burned the dvd, and got a low quality encode. In low quality i mean bad,thin, audio with no punch, and video on fast action scenes gets errors by cyan-type colored blocks coming out of nowhere. I wonder what i can possibly do to avoid this? Any options i can turn on? Btw i used the preset dvd ffmpegx option. I also check encode with quicktime and the letterbox option (the movie is 1.85:1)
Results 1 to 16 of 16
Did you open the movie in FFMPEGX first, and then select the preset? If not the size, bitrate and other variables could have been changed. With the information you provide this is the only thing I could see going wrong other than your source file having some quality problems to begin with.
Cheers
Alph
yes, i did drop it in first, and then i did what i have to do. These errors only appear on TV, incidentally... when i used apple's dvd player, i didn't see them.
Is the mpeg-2 ffmpegx option supposed be a "high quality" mpeg 2 encode as opposed to the mpeg2enc?
There is no reason why these digital blocks should be appearing on fast moving action scenes. iDVD encodes flawlessly but does not let me input a file longer than 90 mins.
Will upping the bitrate help? I hit "best", and ffmpeg calcuated about 2994 to be best quality.. should the videobitrate be 4000? it was blue..
Qmin setting used (lowest rate for VBR)? Makes sometimes big difference IMHO.
I usually use also HQ-option, 4 motion vectors, Trellis quanization and Qpel-options, as they are supposed to improve quality. Takes more time, but it's speedy enough even with my humble Sawtooth running at 450MHz.i-NCO
If this is only occurring on your TV, then it could be that your DVD player does not like the less than constant bitrate that ffmpeg creates. In my view, ffmpeg provides slightly better quality than mpeg2enc, but it's not a truly constant bit rate encoder. High action can cause data-rate spikes. You should try using mpeg2enc to see if your dvd player still produces those errors. Mpeg2enc is slower, but turning off decode with quicktime can speed things up a little if you don't require letterboxing.
Increasing the bitrate beyond "best" has never visibly increased quality for me. I seem to remember major saying adding up to 10% more can in some cases help, but beyond that that little is gained.
Alph
miksu: my qmin was 2 and max was 20 and i had hq on only.
aplh:
That could be the explanation. I will try mpeg2enc, so should i just check the "constant bit rate mark?"
And i do have to letterbox, but in mpeg2enc i dont have to have decode with quicktime checked for the letterbox option to be checked.
and also what is your take on the audio? I heard ffmpegx doesn't normalize correctly. Should I use a.pack for encoding to ac3 and then make a video_ts out of the ac3 and m2v file?
I believe the preset turns on that constant bit rate check box. Just drop the file, select preset and the only changes I make are to video (click best) and audio bit rates. I'm no expert on mpeg2enc, but I seem to remember some weirdness when trying to letterbox without quicktime. Best advice is to test it: if you have a DVD-RW, just use a 10 minute video clip and try different configurations.
If using mpeg2enc still gives you those artifacts my conclusion would be that there is something in the original source that is not decoding properly with ffmpeg. When using mpeg2enc, if you uncheck both decode with quicktime and mplayer, ffmpeg decodes as was probably the case when you encoded with ffmpeg if you had unchecked decode with quicktime.
Alph
last time i encoded with ffmpeg but i also had quicktime and letterbox on.
And thats a good idea, instead of wasting dvd-rs i'll get a dvdrw to do experiment.
After my previous post here I did a little testing with the various decoders under DVD mpeg2enc: quicktime, mplayer, and, if both off, ffmpeg.
-Quicktime and ffmpeg are about the same speed.
-ffmpeg generated errors, and even failed once
-mplayer worked fine, but was slower than either of the other 2.
From this my conclusion would be that the preset, not that I would ever doubt major, is correct in that decode with quicktime is the best option with mpeg2enc.
Alph
dammit. mpeg2enc is not working like it should. It gives me a error at the end and it encodes most of the file but it cuts off the end. Heres the last few lines of the info (i have encode with quicktime checked and letterbox):
Input #0, wav, from '/Users/druzetito/Desktop/newdusttest/dust3ivx.wav':
Duration: 00:01:59.2, start: 0.000000, bitrate: 1411 kb/s
Stream #0.0: Audio: pcm_s16le, 44100 Hz, stereo, 1411 kb/s
Output #0, mp2, to '/Users/druzetito/Desktop/newdusttest/dust3ivx.copy':
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
size= 18176kB time=105.5 bitrate=1411.2kbits/s
size= 20548kB time=119.3 bitrate=1411.2kbits/s
ffmpeg version 0.4.9-pre1, build 4736, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads
built on Jan 7 2005 02:34:06, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
video:0kB audio:20548kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/druzetito/Desktop/newdusttest/dust3ivx.m2v looks like an MPEG Video stream.
**ERROR: [mplex] File /Users/druzetito/Desktop/newdusttest/dust3ivx.copy unrecogniseable!
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
it seems its creating some .copy file for no reason. dunno why.
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Should I encode my movies to DVD?
By rocky12 in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 02:00 -
Re-encode DVD
By greg0ry in forum Authoring (DVD)Replies: 1Last Post: 25th Mar 2009, 02:59 -
Can't encode avi to dvd
By Markcoruk in forum Video ConversionReplies: 4Last Post: 5th Dec 2007, 08:23 -
Best way to encode .m2t to DVD-R?
By paslay in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2007, 13:28
