hey, i have burned a DVD file format a map called DVD-video i have burned with nero 6 (tried burning iso and DVD video) anyway powerDVD plays my VIDEO_TS but my DVD player not (there is nothing wrong with my DVD player) i have created a DVD menu with DVD menu and i created my DVD with DVDmeastro does anyone now what's wrong??? because i don't now the problem (DVD burned 2X speed and it's a DVD-R -
this is the media info of the DVD
Media Information
Disc Regions are 1,2,3,4,5,6,7,8
Media code/Manufacturer ID TTG01
Format Type UDF 1.02
Volume Name VID
Application id
Implementation id DVD Shrink
Recording Date/Time (mm/dd/yyyy) 3/ 5/2005 0:40:31
Format Capacity 2.94GB(3.15GB)
Book Type DVD-R
Media Type DVD-R
Manufacturer Rated Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 08
2x Speed OPC power 0F
2x Write Strategy field 1 11 87 78 80
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 05
4x Speed OPC power 16
4x Write Strategy field 1 0D 0F 0A 09
4x Write Strategy field 2 97 07 0F 0B
4x Write Strategy field 3 80 00 00 00
4x Speed OPC beta multi-pulse 05
4x Speed OPC power multi-pulse 1B
4x Write Strategy field 4 13 A8 89 65
4x Write Strategy field 5 B6 89 88 80 00 00
4x Write Strategy field 6 00 00 D0 00 00
Data area starting sector 30000h
Data area end sector 177BB0h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Complete Media Code
00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 86 0D 13 .l...@....R.....
00000010 66 78 80 00 03 54 54 47 30 31 00 00 04 00 00 00 fx...TTG01......
00000020 00 00 00 00 05 88 80 00 00 00 01 00 06 08 0F 11 ................
hope you know what's wrong (ps there is nothing wrong with my DVD player tried on several DVD players to play never works it
and also burned DVD 3X. again )
Results 1 to 10 of 10
What brand dvd player is it. Did you check the DVD webpage here to see what features your player has.
Probably the disc type... chech to the right under DVD players for format compatibilities.
It used to be that PS2 would play virtually NOTHING but commercially pressed DVDs. Don't know if this has changed.
Pry open that wallet of yours and by a "real" DVD player!ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Is said before, he don't use ps2 as dvd player.Originally Posted by SLK001
He just open anoter topic with same name.
https://www.videohelp.com/forum/viewtopic.php?t=261852
Instead replay on old one, and save time. -
yes, indeed because on the old one i didn't get any respose at all only from the mod. he said to give the media info so i did AND I DON'T USE PS2 AS DVD PLAYER
Tried on several DVD players to play never works it
for those that read my post completly -
Well, for those of us who "read my post completely", your Computer Details:Originally Posted by freezera
Operating System: winxp sp1
CPU Speed: athlon 1800
Harddrive space: 240
RAM Memory: 512
Video Card: Geforce 3
Capture Card:
Motherboard:
CD-ROM:
DVD-ROM:
CD Writer:
DVD Writer:
Standalone DVD Player: playstation 2
Other:ICBM target coordinates:
It wouldn't hurt to add an empty AUDIO_TS folder... It might work then. I have had it happen on me once that when I copied a DVD manually (copying the video_ts folder by hand that is) and forgot to copy the accompanying (even though it usually is empty) audio_ts folder, the DVD would not work, while when adding a audio_ts folder and burn the dvd again, the dvd would work in a certain standalone player.
This audio_ts is not required however and some burn programs don't even make them, but it is placed on the dvd (and left empty) for compatibility reasons. I have come across DVD players that would not work without this folder. Most work without it though...
PowerDVD plays DVDs with limited colors
By semmel in forum Software PlayingReplies: 3Last Post: 4th Jul 2008, 10:57 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 18:25 -
subpictures work on powerdvd but not standalone player
By domhnall in forum DVD RippingReplies: 6Last Post: 19th Aug 2007, 08:12 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 12:07 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 22:15
