I timed some text with another program and I wanted to use the times from that in after effects to save me time BUT in the timeline you can only do for example 1.29 sec and then instead of 1.30 sec you have 2 secs. Where's 1.30? 1.31? etc etc etc
There is half a sec missing which makes it hard to time it when I have a time like 14.84. How would I do 14.84 in after effects?
Confused :/.
The "fractional" part is FRAMES. Since there are 29.97 frames per second, then the next count after 1.29 is 2.00.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Use:
30fps x .86s = 25.8 frame.
Round to the nearest frame, so use 26.ICBM target coordinates:
When dealing with video in after effects, think more like Timecode and less like Feet/Frames.
What is the time 1 second after ( hr:mn
ec) 11:59:59? 12:00:00 !
It's Zerobase-incrementing (computer style), not Onebase-incrementing (like most humans count). There are actual terms for this, I just can't recall at the moment.
So 1 sec, 29 frames + 1 = 2 seconds.
Not 1 sec, 30 frames. It actually is the same thing, but you just don't count it or say it that way.
When you say 14.86--do you mean [14.86 sec] or [14 sec + 86 frames] or [14.86 min] ... or what?
That's one good reason for using true timecode numbering--
HR:MN:SEC:FRAME with ":" used before the frame section for non-dropframe NTSC, and ";" used before the frame section for dropframe NTSC.
Assuming you meant 14.86 sec, then SLK001's estimation is correct.
Mouse wheel timeline zoom problem with Vegas 11
By sdsumike619 in forum EditingReplies: 9Last Post: 7th Aug 2012, 15:57 -
Editstudio Pro 6: Effects problem
By Sillyname in forum EditingReplies: 0Last Post: 14th Aug 2010, 19:59 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
Audio effects problem
By SearchQuality in forum AudioReplies: 0Last Post: 26th Oct 2009, 11:55 -
Problem with masking in after effects cs4
By Morten in forum EditingReplies: 6Last Post: 16th Aug 2009, 07:52
