Ive been doing this stuff for about 3 years and this is a first.I recently changed to taking vidio on my Canon GL2 to frame mode Im not sure but I think this is the problem.When I capture the footage from the GL2 to Ppro 1.5 I keep getting this error (Error audio format changed during capture)so I poke ok and continue then it does it againa few minutes later.I was able to capture the whole movie with the mainconcept standalone but when I played the movie back the audio sounded slowed down.Any help would be great.
Not sure what's going on, but check if you accidentally switched between 32khz and 48khz audio in your camcorder settings.
Also, are you capturing DV Type-1 or Type-2 .avi's (or some other format like on-the-fly mpeg encoding)?George -
George you were correct when I played back the tape and watched the veiw finder it changed from 16bit to 12bit inbetween clips and then back to 16bit now I just have to find out why.
Thanks -
I found out that I used this DV tape before then I stripped it then I recorded over it and in between clips it picks up that I did a 12 bit recording last time thats whats causing my pain
Best format to capture in?
By Canopus Smoker in forum Newbie / General discussionsReplies: 10Last Post: 27th Nov 2008, 14:14 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59 -
what is the best format when capture from tv show?
By sumeshkri in forum Capturing and VCRReplies: 10Last Post: 23rd Feb 2008, 18:35 -
WMV Format Capture
By zerohash in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2007, 08:48 -
best capture format and software
By boots in forum Capturing and VCRReplies: 11Last Post: 27th Jun 2007, 19:54
