Would appreciate it if someone can explain to me why I can import a vob file in adobe premiere but the audio track doesnt appear...yet if I play the VOB file the audio is there...Is it that Premiere cannot separate the audio track from the vob file?...a bit confused since if I import an avi file..adobe seems to have no problem in separating the audio track....
Appreciate any explanation of this..a bit confused about it...
also is there a different type of audio codec that is used when you create a recorded DVD using a freestanding dvd recorder?
Many thanks for information
Nick
VOB files will usually have AC3 audio. Although it can have other formats also. It may be possible that your adobe premiere is not able to recognize AC3 audio. Do you have all the required audio plugins for your version of AP ?
When I was born I was so shocked that I could'nt speak for 18 months. -
Thank you for the info. I dont know if I do have all of the plugins...frankly never looked and not sure where to get the AC3 plug in...
Looking for an explanation of strange behaviour
By Duwgati in forum Authoring (DVD)Replies: 6Last Post: 29th Jul 2011, 08:03 -
Codec Explanation, which is best for this scenario ...
By andrewbutkus in forum Video ConversionReplies: 30Last Post: 1st Sep 2010, 11:15 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
