I am trying to compress a large video file, it is about 5 gb and I need it to fit onto a standard dvdr. It is a nero show time file, specifically xvid. what is a good program to compress this, along with .avi, and mpeg, and various other video format files? Can anyone help?![]()
Closed Thread
You can also use AutoGK. It has a file mode that allows you to compress it to about any size that you want it to be.
If you want to fit your file on a DVDR then you need to encode it to a DVD compliant MPEG2 file. Use can use TMPEGEnc for this. You may need to adjust the video bitrate to make sure that the encoded file fits onto a DVDR
When I was born I was so shocked that I could'nt speak for 18 months.
https://www.videohelp.com/forum/viewtopic.php?t=263864&highlight=
Don't post the same question twice
. If you'd simply given more details the last time you posted the question, we could have actually helped you....
Video encoding compression
By bbbbbbb45 in forum Video ConversionReplies: 11Last Post: 26th Mar 2012, 08:30 -
Need help with video compression
By jrru2 in forum Video ConversionReplies: 3Last Post: 2nd Nov 2011, 02:35 -
Video compression
By AntiBaltak in forum Video ConversionReplies: 2Last Post: 9th Nov 2009, 18:20 -
So many Video Codecs to comprehend; best Video compression?
By bulava in forum Video ConversionReplies: 7Last Post: 3rd Mar 2009, 16:01 -
video compression
By avextraxjp in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2009, 07:18
