  1. Does anyone kow why when i burn a video_ts folder to a dvd the audio seems to go out of sink. I've been trying it with nero 6 and TMPGEnc but the results are the same. Does anyone have any good process for converting video_ts folder to a dvd?????
    Thanks Peep's
    Apr 2004
    Miskatonic U
    I have never had a disk go out of sync because of the burning process. Are you sure the dvd on your hdd isn't already out of sync ?
    Read my blog here.
  3. Burning files to dvd will not cause the audio to go out of sync. It may be possible that the files (VOBs)in your VIDEO_TS folder already have out of sync audio. Play them on your PC first to check.
    However more details are required from you. How did you get the VIDEO_TS folder ?
    When I was born I was so shocked that I could'nt speak for 18 months.
