  1. How do I place the subs that I add into the TextSub filter into the letterbox of a video? I'm making an OGG file, and the video and audio streams come out great. However, the subs are in the video on the bottom center instead of in the black letterbox. How do I move them?
    Using VirtualDubMod w/ TextSub 2.23.
  2. Originally Posted by slippygod
    What happened when you adjusted the Margin settings?
  3. The margin settings just put it closer to the bottom of the video. The defaults were all 20; when I changed the one for Bottom to 0, it was just at the very bottom of the video, on top of the letterbox.
    Dec 2004
    Australia
    Making an ogg file? So therefor you must be using ffdshow with theora for encoding? Enable video filtering in ffdshow and then load the subtitles. Just tested it and it works fine here.
