Hi. I have of late yet I know not why been in perplexed misery.
Who in the the lands and coves of video, know the secret to unlock this question...
The problem at hand:
1) Say you have faithfully recorded, captured, edited, and finalized a dvd for every e.g. birthday, e.t.c.
2) Now comes the time when you want to compile a best of dvd. Re-tracing every step in 1) is overwhelming. The easier way is to reopen the already finished dvd´s.
3) authoring the new dvd should, be a brise because everything is native DVD language.
Tried and tested modules are:
Womble mpeg video wizard, for the purpose of opening and editing in an vob file, or grabbed file on harddrive.
Workes to the point, fast reliable on test subjects.
Problem authoring the new files ends up in elongated rendering time.
Tried module here:
Sony DVD architect 2.
Wanted: Burning program that sets up playlist and needs no reencoding of the files.
Is this posible?
There are a couple of ways of doing this. If it were me, I'd probably use DVD Shrink to isolate the parts that I wanted, and write them of to seperate VTS on the HDD. I would then use DVD Lab Pro to demux the VOBS within (probably only one vob per clip, assuming they are small), then author with menus/playlists etc as required. Shrink will take care of the video and audio. It isn't frame accurate, however the judicious (sic) use of chapter points and play lists can repair this afterwards.
You could also use tmpgenc DVD author to assemble everything.
If you are happy with what womble has produced for you, download the trial version of DVD Lab Pro from Mediachance. It is fully functioning, and will produce the DVD structure for you. You just need to burn it to disk and your done.Read my blog here.
Using DVD shrink? Very interesting, but how? I must be missing the obvious. Has anybody got a tutorial all worked out?
Editing TiVo Recording (MPEG2/AC3) with MPEG Streamclip loses audio
By DarthEd in forum MacReplies: 15Last Post: 4th May 2012, 08:28 -
Can I capture/copy DV directly to DVD MPEG2?
By shina00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 17th Nov 2011, 07:16 -
Viewing mpeg2/AVCHD directly from a SD card on a TV
By Ravis in forum Newbie / General discussionsReplies: 5Last Post: 6th May 2010, 14:53 -
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Mar 2009, 07:21 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
