I just bought a sony DVD writer and it came with the nero suite of products. There is a bunch of information in the write up around backing up DVDs stating I can do it if they are "not copy protected". Does this mean I won't be able to backup any of my store bought movies using only Nero? Or should I be able to back them up no problem without other software?
No it just means that you will need to find a way around the copy protection. If you use a tool called dvd decrypter to copy the copyprotected dvd to your hard drive you can then use Nero to compress it and burn it back to a dvdr disc.
DVD Decrypter for ripping to hard drive.
DVD Shrink to compress to 4.37GB.
Nero to burn. -
DUDE, just think about it for a minute. Do you really think that a commecial money making company like Nero will outright tell you how to copy a protected DVD. They would be sued as fast as you can bilnk. THey HAVE to state that it is only for Non Protected DVDs.
Download DVDShink ( Free ) Set ip up to burn the resulting DVD files with Nero and your drive ( Drive letter ) That's all you really need. Read Read nad then Read some more. There are a ton of guides that will teach you all you need to know about DVD Shrink as well as DVD Decrypter. Look to the left.No DVD can withstand the power of DVDShrink along with AnyDVD! -
But if he owns Nero Recode he should use that because its quality is far superior to DVDshrink.
Thanks to all! Don't worry...I have been reading. I am actually very well versed in the VCD world thanks to all your past help and product guides from here. I finally got with the program and stepped up to DVD. Thanks for the input!!!
Bought a Sony AVCHD camcorder, now what?
By gom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 30th Dec 2011, 22:52 -
Resyncing a recently bought DVD
By Worst.episode.ever in forum DVD RippingReplies: 3Last Post: 10th Mar 2010, 03:59 -
Help with Pioneer DVD Writer DVR-112D and Nero
By tdoran70 in forum DVD & Blu-ray WritersReplies: 6Last Post: 1st Sep 2008, 17:23 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
recently bought dvd
By jadair7576 in forum Software PlayingReplies: 42Last Post: 7th Mar 2008, 10:28
