I just bought the ND3520A drive but it didnt come with any installation instructions so i don't know how to install it properly. Could anyone tell me I'm supposed to do this, i went on the nec website and they have the instructions but its in deutche.
all u need to do is pull out your old drive and plug in the ide cable. on the top it shows how to make it a slave or master or whatever. it should be on defult slave. plug in and go
Jessica Alba #1 -
some (definitely NOT all!) DVD burners can ONLY be installed as the Master Drive on the 2ndary IDE slot with no slave attached
after it's installed you can then add a slave drive, but if you want/need to update the firmware, you must unplug your slave device
again, this is only on SOME DVD burners, NOT ALL.
YRMV"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!"
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 13:25 -
Would you still buy an NEC ND-3520A today?
By Number Six in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Mar 2008, 09:24 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
