My master writer is Pioneer DVR-108
My reader is LG GCE-8520B
For some reason the dvd-reader drive won't detect disks![]()
Any ideas why this is happening?
any type of discs or just burned discs?Originally Posted by stussy
i've tried only burnt ones.
What is also strange is that I just reversed the master/slave ones, causing the reader to be master and burner to be slave. It can read cd's but not dvd's/. -
I have a Pioneer 108D and a LITEON reader. The reader will not read Optodisc R004 disc's. I am waiting for Liteon to update the F/W for the reader. Suggest you may be experiencing a similar problem. Check to see if there is a F/W update for your burner.
About Master \Slave, I would have the burner as the Master and the reader as the slave.
Philips 42PFL9664H doesn't automatically detect when a DVD is started
By holmerz in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Aug 2010, 09:18 -
recommended player/reader for scratched disks?
By octeuron in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2010, 00:23 -
Mplayer doesn't detect PCM in ts/m2ts
By qkthr in forum Video ConversionReplies: 2Last Post: 28th Jan 2010, 00:26 -
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 01:48 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 10:46
