    Jan 2005
    What program should I use for the Mac to make a DVD-R XBOX and PS2 compatible?
    I made a dvd with iDVD 3, and my xbox did not recognize it. I dont know about ps2.
    Is there a set of rules for this ? Ive read that for the the PC, nero has an option to enforce compatibility, so is there something like this for toast 6?
  2. I believe that the main issue is media rather than any specidic program. As long as you have a valid Video_Ts (test it out in the DVD Plauer first) you should be okay. These are the pertinent reviews:
    https://www.videohelp.com/dvdplayers.php?DVDnameid=876&Search=Search&#comments
    https://www.videohelp.com/dvdplayers.php?DVDnameid=445&Search=Search&#comments
    Jan 2005
    ah great info thanks. Exactly says there.. i used fujifilm 8x dvd-r and it didnt read. Doesnt say anything about this type on the ps2 but i assume it can read since most fujifilm reads on it.
    Jan 2005
    Ok well i looked at the list again and its fairly confusing. Does anyone just know what brands of DVD-Rs are generally known to work on the xbox?
    Mar 2003
    try verbatim or apple dvd-rs never really ever had a problem with their media
