Just wondering if anyone else has had trouble burning mp3 or cd's with i tunes, it says it cant complete burn or retry? It seems to be a recent thing.
Results 1 to 9 of 9
no.
more info please:
What OS version
what burner
What version of iTunes
is this a factory burner, or third party install
etc."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
OS 10.2.8
Matshita cd-rw 8572
i tunes 4.7
Factory install, G4 mirror door
It used to burn no with no problems, but I cant remember if it was after the last software update or not, it starts to write the first song and then it says canceling disc burn in the activity window, then it spits the tray open with a message on the screen
Heres the exact message.
'The attempt to burn a disc failed, the device failed to respond properly, unable to recover or retry'
It dosent work if you try to burn a cd or mp3. -
A few things to try:
Try cleaning the lens of the CD drive.
Radio Shack sells a good lens cleaner,
as does Office Max and Staples made by Fellows.
also, try a diffrent brand of CD-R media. Pick up some TDK,
Maxell, or HP Branded media.
post back and let us know the results."Everyone has to learn, so that they can one day teach."
Urban Mac User -
I noted the SAME thing with mine since going to 4.7
I usually just get a 2nd cd and it will work then! -
Tried lens cleaner, different media and re-trying but it still does not work, although I have no trouble backing up photos in iphoto?
upgrade to iTunes 4.7.1?
http://www.apple.com/support/downloads/itunes471.html"Everyone has to learn, so that they can one day teach."
Urban Mac User -
I haven't had any problems since upgrading to 4.7. Sounds like you may wanna get Apple support involved.
There are 10 kinds of people. Those that understand binary and .... -
I changed the prefered drive from the matshita to the pioneer dvr 105 and it works no worries, thanks for your help and ideas, it looks like I need a new cd burner, choices choices.
CD ripping (not vids, but tunes)...
By cwb in forum DVD RippingReplies: 13Last Post: 9th Sep 2011, 09:46 -
Should I download I-Tunes 10.4.1
By Tom in HD in forum MacReplies: 2Last Post: 3rd Sep 2011, 00:46 -
I-Tunes crashes every time I try to play something :(
By Akhet in forum ComputerReplies: 4Last Post: 8th Dec 2009, 18:59 -
AVI to I Tunes
By cobraper in forum MacReplies: 9Last Post: 3rd Aug 2008, 16:41 -
How to copy a CD w/tons of mp3 tunes to another CD??
By rbatty11 in forum AudioReplies: 6Last Post: 19th Jun 2007, 20:30
