After nearly a year of disappointing results, and almost tossing the card out the window, I FINALLY got some results I am happy with! If you're having problems with this card and its esults, here's what I did:
First of all, here's my specs:
- WinXP
- 1.7GHz
- 512 MB SDRAM
- 80GB 7200RPM HD, 30GB 5400RPM HD
Following a tweak guide I read on http://www.videoguys.com I moved my swap file to my second HD. SInce I'm running XP I didn't need to upgrade to DirectX 8.1, but if you don't run XP you should upgrade. After that, I got ahold of MMC 7.5, the new version of the software that comes with the ATI card. This software actually comes with the ATI 8500 card, it's not available on their site but it's fairly easy to find on the 'Net. Make sure your HD(s) are DMA enabled.
In the Setup for the TV component of MMC 7.5, use these settings:The results were amazing. After routinely dropping 30%+ frames while capturing for DVD, I am now losing < 1%. I've only run a few tests with other settings (i.e. AVI and MPEG1) with fair results, but the above setup gives me a nice smooth motion and high quality capture. If you're making VCDs then it's not gonna work, since the cap is straight to MPEG2, but if you're doing DVD-R (which I am) it's finally going to give you a capture that's usable.
- 640x480
- Audio = 44.1KHz, 16 bit Stereo
- MPEG2 w/De-Interlacing and Visual Masking enabled
- 4 P-Frames, 2 B-Frames
- Variable Bit Rate = 8.0 MBit
- Motion Estimation = 100
- Motion Estimation Search Ranges = 32 Hor, 16 Ver
John D.
<font size=-1>[ This Message was edited by: Xanadu on 2001-12-12 05:09:35 ]</font>
Results 1 to 1 of 1
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 11:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 21:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 15:52 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 16:25 -
H264 x264 ATI Radeon Vid Card Question
By mforcex in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2007, 10:59
