Hi
I haven't brought a Dual Layer DVD RW yet (I'm still a newbie).
After reading Encores help files I am confused if 1.5 will burn to a double layer disc.
It states;
Dual-layer disc
To create a dual-layer disc, you first must write your project to two separate DLTs (Digital Linear Tapes), one tape for each layer of the disc. (See Build Options.)
I wanted to buy the SONY Dual Layer ReWriter - so that I can get 8.5GB per disc. I not sure what I should do now.
Thanks, Stephen
Results 1 to 12 of 12
If that's all it says about DL, then that means it doesn't support writing to Dual Layer Recordable discs. DLT refers to the backup tapes to be sent to a factory for replication (not what your looking for).
Wait for next version...
Scott -
OR write the output to your HDD as a large single layer dvd, and burn with a DL capable burner (Nero, DVD Decrypter, CopytoDVD etc). You may not have complete control over where your layer break will be, but it should work. Many people do this when they can't be bothered getting bitrate correct, then use DVD Shrink to make it fit on an SL disk.
Read my blog here.
Yes, can be done that way, but the better way would be to use a "Recordable DL-aware" app, such as RecordNowMax.
Scott -
The Adobe Encore 1.5.1 update supports dual layer burners:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=2663
Adobe Encore DVD 1.5.1 update
The Adobe® Encore™ DVD 1.5.1 update adds support for dual-layer DVD burners and addresses a few key issues that were identified in version 1.5. It is highly recommended for all users of Adobe Encore DVD 1.5 software.
With Adobe Encore DVD 1.5.1, you can burn a project to a dual-layer DVD disc. Dual-layer discs are single-sided discs that have two recordable layers on one side of the disc, effectively doubling the amount of data it can hold. To create a dual-layer disc, you will need dual-layer media and a DVD burner that supports dual layers. Check your burner's documentation to see if it can create dual-layer discs. -
That's good, but does it explicitly allow you to set the LayerChange point?
Scott -
I think Encore splits the movie automatically. It finds the best point (in term of the size) where the split can be made.
I have question.
If I have Dual Layer project and I want replicate DVD in factory,
do I still need backup tape on DLT tapes or Dual Layer DVD will be
accept for replicate DVD in factory?
Or its depending on DVD replicate factory? -
I would say "Depends on the factory". Currently, many factories accept only DLT, DVD-R (Authoring), or DVD-R (General). Some may accept DVD+R, but I haven't been in contact with any lately. Since DVD-R DL isn't an easy reality yet, your chances are slim. However, this will probably change for the better in the not-to-distant future.
How long can you wait?
Oh, yeah, one other way they will take is with removeable HD.
Why don't you check with the factories themselves...
Scott -
Yes but to get what you pay for , you must use DLT tapes still.Or its depending on DVD replicate factory?
this is because the track record is not written for dual layer master yet, and the replicators out there doing this are taking heat for making jobs that are "bad" because they didn't use a D.L.T.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 17:13 -
HP DVD+R Double Layer Discs
By SEE_Studios in forum MediaReplies: 57Last Post: 15th Apr 2010, 09:56 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 14:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 12:27 -
Double Layer DVD
By nagihcim1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Sep 2007, 20:09
Hi
