Hi,
I just got a Pioneer DVR-109 which I plan to install in my Dell 8400, replacing the problematic Phillips 8631 which came with the machine.
Simple newbie question: do I need to "uninstall" the old unit (drivers?), via Device Manager before pulling it out and plugging in the Pioneer? Or is it as simple as a) pull out old unit and b) put in new unit, letting PNP do the rest?
I also plan to upgrade the firmware to 1.40 once I get it going. Any tips for safely doing that?
TIA!
Just remove the old burner. Make sure the jumper settings on the new drive match what is on the old drive. Put everything back to gether. Boot the machine, ther PC will see the new hardware.
Your best bet is to follow the installation instructions supplied by Pioneer.
If you dont have such instruction go to their web siteand get them.
It can be as simple as out with the old and in with new.
Windows with find the new hardware and prompt you for what action to take. -
Go here for more info on the firmware.
http://club.cdfreaks.com/forumdisplay.php?f=87 -
Thanks for the quick replies!
I had read on the Dell forum about setting the jumper to 'cable select' which, I guess, is their standard way of setting-up their machines.
The instructions provided with the Pioneer were pretty bare, and were geared towards the first-time installer, so I will go to the Pioneer site to see if they provide more beefy instructions there for the replacement situation. It makes sense to me that PNP would be able to handle it, but I'm glad you confirmed that, Bodyslide.
I've got the "official" Pioneer firmware, so I should be OK. I'll have to do more reading before I understand why I'd want any that were modified... my needs are pretty simple, so I doubt that I'd go that route.
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
Replacement for MY DVD
By ccm2 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2008, 13:19 -
Daytek 950-S burner replacement request
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Jul 2008, 09:24 -
Replacement DVD Writer Interface
By LiCal in forum DVD & Blu-ray WritersReplies: 7Last Post: 14th Mar 2008, 14:08 -
Replacement DVD RW Drive
By tantrik in forum DVD & Blu-ray WritersReplies: 9Last Post: 8th Feb 2008, 13:54
