  1. Member GreatSinatraFan's Avatar
    Feb 2002
    Dallas Texas
    DIKO is great; the "DivXHighQuality.Avs" script worked wonderously well with every AVI file I've tried.. then we built a new faster PC, re-formated the drive, and reinstalled DIKO.. .NOW all I get when I try to use this DivXHighQuality script is error messages; such as "Can't find a certain .dll file" OR this one; I see this one all of the time=
    "Script Error: there is no function named "Deen" (D:\Videos\Working Diko Folder\movie0.avs, line 40)
    Huh? Why am I seeing all these script errors? DIKO still works well with the original "DialhotV4.avs" script..but what can I do to get the high quality script back to working correctly again?
    I've tried UN-installing Diko..rebooting, then RE-installing it again; but DIKO still doesn't work correctly as it once did.
    Any thoughts ? Thanks !
    Ring-a-Ding-Ding!
    Dec 2004
    Australia
    You need to either load deen in your script or make sure that the dll is in your AVISynth plugin dir so that it will autoload.
