is there any way i can apply an animated gif on top of an avi file so they play at the same time.
i have tried a vdub logo filter using animation setting but it didnt work properly
any suggestions plz![]()
Old and Bored
Yet Self assured
Oh I know a dirty little word -->Encryption -
The answer is always AviSynth
. Heres a small script i used to display Slideshows in the lower right corner of PAL DV footage, i rewrote it a little to better match your scenario:
LogoClip = ImageSource("D:\dv\Tape9 W1\0%d.bmp", 1, 6, 5)
LogoClip = BicubicResize(LogoClip,60,60,0,0.5).ConvertToYUY2( )
LogoClip = Loop(LogoClip, 400)
LogoClip = ChangeFPS(LogoClip, 25)
MainClip = aviSource("D:\dv\Tape9 W1\uvs050407-002-1.avi",True).ConvertToYUY2()
Return Layer(MainClip, LogoClip, x=600, y=480)
First step is to open the GIF in ACDSee; click on Tools -> Format Convert, click the button Multipage Options, then save it as individual Bitmaps. In my script the ImageSource function will read bitmaps 01.bmp through 06.bmp and play them at 5 FPS (change to a number that matches the speed of your animated GIF most closely), the framerate is later changed to 25 FPS for PAL in the third line to match the framerate of the main video, you would want to change this if your video is NTSC.
The Loop function (2nd line) repeats the clip 400 times, you will need to set another value here so it will match the length of your main video.
x and y in the last line is the position where you want to place the Logo on the main video meassured from Left-Top.
Look for more info on http://www.avisynth.org/AviSynthManual
Edit: Fixed some linebreaks in the script.
Insert animated gif in movie clip - avi, swf or else
By wilderwildness in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 09:45 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 21:02 -
AVI to animated GIF
By snafubaby in forum Video ConversionReplies: 10Last Post: 12th Nov 2007, 23:33 -
Adding subtitles to an AVI
By ker-plop in forum MacReplies: 12Last Post: 8th Oct 2007, 09:48 -
convert AVI to GIF
By ecos in forum Newbie / General discussionsReplies: 1Last Post: 18th Jul 2007, 12:17
