Hi,
I like in the UK and I have a Panasonic DMR-E55 standalone DVD recorder.
When copying from another DVD player the DMR-E55 has given me no problems regarding PAL or NTSC format, due to the changeable recording settings.
However, for some reason when trying to copy from a video source, it will only record PAL format sucessfully.
I have some US NTSC videos, and can watch these fine when simply playing through the VCR plugged straight into the TV. When I connect the VCR to the DMR-E55 however the DMR just doesnt seemt o be able to sense the picture - if I leave the DMR in PAL format setting then there is a large obtrusive bar running accross the bottom of the screen, and if I turn the DMR format to NTSC the picture comes out only in black and white.
I have borrowed a friends VCR, and have experienced exactly the same problem.
Are the multi-format UK video players somehow changing the NTSC signal into something the DMR cant understand, or is the colour getting lost somewhere on the SCART connection - ie are US SCART cables different than UK ones?
Im getting very frustrated here - does anyone have any ideas as to how I can transfer these NTSC videos onto DVD via my DMR-E55?
Quasi signals, so tv (and ONLY tv) understands the video. Your players do not "convert" anything. That is why.
It's not impossible.
But, as you say, you will need a multi format VCR.
As I understand it, there are two types of NTSC signal output by VCR's here in the UK, 4.43 and 3.58. One of these is true NTSC, which only multi format VCR's can display and the other one is the format which allows NTSC to be displayed on UK TV's (I can't remember which is which though!).
I believe I'm correct, but if not, someone will put me (and you) straight!
Hope this helps. -
Originally Posted by loz
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 16:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 09:42 -
Panasonic TM900 NTSC to PAL conversion...
By vkshatriya in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Oct 2011, 04:24 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33
