Hi, whenever i view video on my pc, either vobs, avi's, mpegs, using either windows media or powerdvd, the playback stutters.....
i've tried re-installing my video card software, but it has not cured the problem..
any idea's ?????
thanks...
Results 1 to 10 of 10
installed any codec packs lately?
installed ffdshow? and using some filter?
try play with vlc media player...does it work ? -
yes, got the latest video drivers for my card, nvidea geforce 5200, and just installed the lastest version of directx, have not reboot, but still occaisional stutter......
Is there too much background activity / processing taking place ??
When I was born I was so shocked that I could'nt speak for 18 months. -
Here are some things to check!
Run AD_Ware or Spybot to remove any spy ware that maybe running.
Scan the computer for viruses.
When doing any kind of video work make sure that all other tasks are closed(ex IE, WORD, games)
Make sure that your video card is not sharing an Interupt.
Make sure that your HD is running in DMA and not PIO mode.
Run a memory test program such as MEMTEST.
Defrag your HD. -
my graphics card is sharing an interupt with my raid card.....
have not run the memory test..... dont have a clue how to change the interupt, my bios is set to auto this, i can set to manual, but cant see interupt 19 listed, in bios of course..... -
This will only be a problem if you have a RAID system.
Procede to check the other items.
I'm having probs with MPC-HC
By HartsVideo in forum Software PlayingReplies: 8Last Post: 10th Feb 2011, 21:47 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
A few probs with FAVC
By kronick in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 20:25 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
Avi conversion probs
By hitmanhill in forum Authoring (DVD)Replies: 15Last Post: 12th May 2007, 09:21
