hi,
the Nero high comp. mode works fine when burning to a DVD-R, but it won't burn 1 gig when using a DVD+R.
Is that the way it's supposed to be ? do i have to add a dummy file to reach the 1 gig to make it compatible with my xbox ?
thanks.
The check box you are referring to, is used to set the recognition code of a +R disc to make it appear as a DVD ROM. It doesn't affect -R discs. It is used to make +R discs more compatible with DVD players.
Google is your Friend -
thanks Kritter for your reply.
according to this thread, high comp mode is here, to burn at least 1 gig. and i've tested it with DVD-R, and that's actually what it does, i burn a 300 meg iso, and it makes 1 gig so it's compatible with xbox. now i would like to burn DVD+R as bitsetted DVD-ROMs, but the high compatibility mode doesn't fill upto 1 gig. and i kinda dislike doing it with a dummy file...
anybody else expirience similar issues ?[/url] -
Recorder Dropdown > Choose Recorder
then click on your recorder and selection options...
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 21:46 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
Ripping blu-ray into divx (high compatibility) with virtualdub
By Urban20 in forum Blu-ray RippingReplies: 19Last Post: 5th Aug 2010, 19:17 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
