Hi,
When I burn a dvd the edges of the footage seems jagged. When I burn in mpeg 2 then it seems OK!
Why would thin happen as dvd is higher quility, could I be doing something wrong?
what is your source?
have you tried other standalone dvd encoders like tmpgenc, mainconcept mpeg encoder? all-in-one tools are easy but not the best if you want the best quality. -
except when it's mpeg1 at lower bitrates and vcd resolution. maybe that software is encoding it that way???Originally Posted by AbondGeorge
Thanks,Originally Posted by GeorgeW
What i do not get is that the mpeg2 disk plays Ok only the footage movement seems slugish. The dvd disc movement is 100% but the edges of for example a person is jagged.
I will have to bouble check the settings?
tahnks
pieter -
it is digital Sony camcorder via firewire.
When I burn the mpeg2 the footage is better but it doesn't seem to be as smooth as with the dvd(with jagged edges).
I don't know, what do you think!
Power director surround sound
By werdna99 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2011, 15:33 -
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 20:05 -
Cant get sound from recorded TV in Power Director 7
By tuiluvva in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2009, 06:11 -
Cyberlink Power Director Problem
By ada1984 in forum EditingReplies: 6Last Post: 17th Nov 2007, 12:50 -
Power Director 6 create disc problem (trouble
By tekton364 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2007, 18:35
