I was making my first ever dvd today when iDVD 3 told me while i was burning and it gave me a rediculously numbered error which its pointless to even record.
Basically i know no one can help me on this so i am here to just say this: idvd 3 is crap. if any CAN help though, it'd be nice. The only thing i like about i dvd is the preset dvd menus..
Im using g4 mirror door, Pioneer 109, DVD-R media from fuji film.
Results 1 to 15 of 15
no, I think he did just fine there......I'm sure hundreds of people are going to drop by and help.....Originally Posted by sjk
well im just simply stating i dont even know HOW i can be helped because the message iDVD 3 gave me told me in no way shape or form why it didn't succeed. In addition, iDVD 3 has no advanced controls to help with bitrate, burning speed, etc..
I successfully burned a dvd in Toast 6 but i don't like its encoding it left a lot of artifacts especially in fast paced video.
I have yet to try with ffmpegx but how can i put menus in there and two or more video files instead of one? -
Of course it doesn't have those controls, since it's supposed to be easy to use, even grandma can use it with perfectly good results. Fiddling with bitrates etc. needs some knowledge, if U want decent quality. Grandma or 12yo kids don't know anything about bitrates, be it VBR or CBR, or quantization matrix. Actually, most people know nothing about them, or videostandards in overall. And still they have to shrink movies. Take a look at those weird AVIs with 512x384 resolution and WMA2-audio at 16kHz... Usually it's also NTSC screensize with PAL framerate or vice versa. And scaled down 20% (640x480 to 512x384), or something creative.In addition, iDVD 3 has no advanced controls to help with bitrate, burning speed, etc..
Therefore, iDVD has more than adequate controls for its intended user base. It makes DVDs that work on most DVD-players. You can always buy DSP and MPEG2-encoder like Bitvice, or whatever U prefer.
And with your accurate description of errors, I am sure there are many people willing to help
Since you have Pioneer 109 drive you should use PatchBurn app first to enable iDVD to work with that drive correctly...
Yeah, that's right. The number was pointless. If you had written it down you might be getting a little more help right now... Since you didn't - no one has a clue what went wrong.Originally Posted by balkandvb
I'll try and be slightly more polite than my fellows,
but for the record, yes you did screw up asking for help
and not telling us what the EXACT error was.
We don't mind you coming here to vent, but if you are
going to come on here and vent, just remember, that
someone else might be having the same problems as you,
and could have benefitted from the help in answering
the question....
That said here our a few common errors that I know
of off the top of my head:
error -1
error -2
these are general finder type errors, usually resulting in
the finder not being able to perform a simple task.
error -3
out of memory error. Not enough ram/vm to perform the task.
error -36
i/o error. Could not access the disc (one example: the disc
is full you are trying to write to)
error- Power Calibration Area Error (0x73, 0x03.)
could not accurattely control the DVD drive, could be
a driver isssue or it could be you need to install Patchburn3."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
yea well my error was with about, hmm.. NINE digits maybe? I supposed that was just a bogus number given by iDVD.
And yes, i do know bitrates and other options iam not the "average" user
So Serbia, i should get patch burn? my firmware is 1.17 i know the latest is 1.40.. -
The firmware of the Pioneer drive has ZILCH to do
with the on board drivers installed in the OS.
from my contribution to the upcoming FAQ:
Firmware on the drive just tells it certain calibrations
necessary to preform certain actions internally,
like burn at this speed, this type of media is acceptable,
this is your on-board buffer rating.
Patchburn "patches" the on board ( read: Native OS)
drivers, that tells the OS how internally installed parts
are accessible/mountable/usable, and what apps have
protocols to be able to utilize such devices.
When Patchburn 3 patches the drive kernal, it changes
the device's ability to be usuable by any apps that use
apple's drive kernals by giving it the status
"'apple [or vendor] supported", which is an all clear
to those apps.
So while your firmware may be up to date, unless the
OS says the device is "'apple [or vendor] supported",
you will still have issues using the drive with apps on the mac,
the iApps [iMovie/iTunes/iDVD] being the most notorious. -
another satisfied customer....."Everyone has to learn, so that they can one day teach."
Urban Mac User
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 20:05 -
iDVD and subtitles
By Sgaar in forum MacReplies: 4Last Post: 4th Jan 2009, 22:37 -
No Audio in iDVD
By The Monkees in forum MacReplies: 8Last Post: 12th Feb 2008, 18:35 -
MPG's in iDVD
By The Monkees in forum MacReplies: 12Last Post: 10th Jan 2008, 17:56 -
No Sound in iDVD???
By TheMikesmith in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 11:48
