I have tried very hard to search for this in the guides. I think there needs to be a keyword search function for guides, but that aside, I would like to know how to go about backing up PS1 and PS2 games.
Results 1 to 15 of 15
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
PS2 (needs to be 'chipped') - DVD Decrypter ISO read/write
PS1 - not a clueHe's a liar and a murderer, and I say that with all due respect. -
A modchip is one option. Others would be getting a fliptop case or using a slide tool to pop open the disc tray.
jawgee -
www.gamecopyworld.com or any other of about 580,000 web pages (googleOriginally Posted by Nilfennasion
)might be better suited for your searching
If in doubt, Google it. -
I rip to the HD a disc image with nero and burn the image file with nero. I have a fliptop ps2 with swap disc and I've only had a few out of 30+ backup ps2 games that wouldn't work. Fliptop case is pretty simple and easy to install
Modchip installed
All you need is the ALCOHOL 120% program to rip and burn -
You can backup with any dvd copy program. They aren't copy protected until you put them in your ps2......
Was a cool program, Bleem, that let you play PS1 games on your PC. -
Okay... how does this work, and where can I get one? Most importantly, does it void the warranty? I've been looking about and it seems the best option for me.Originally Posted by strummy53"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
The fliptop voids the warranty cause you have to take the cover off to put it on,you can use a slidecard or a knife to slide the mechanism and pull the tray out to put the backup in after you take out the swap disc.
With the new pstwo all you need to do is use plastic q-tips to hold down the switches and use the swap disc that way,no taking apart either.Google for modchips and you will find a lot of places.
I find dvd decrypter the best program to rip ps2 dvds and alcohol 120% for the ps2 cd games.
There's much better programs now to play psone games than bleem could ever play.I think,therefore i am a hamster. -
Like which one, please let me know. I have bleem but have stopped using it. There was another, psx station I think, can't remember. but both never really worked perfect. Please link to the ones you know are better.
http://www.zophar.net/psx.html
Theres a few here that are good,ePSXe is one to try.I think,therefore i am a hamster. -
Go with an internal mod chip. Swap tricks suck. Although if you don't know anyone who can solder... hehe. *shrug*
Voiding your warranty with a flip top mod is avoidable on a new PS2 slim model. Just use the warranty sticker as a hinge when you open the PS2. Works great!
Gamecopyworld has some great tuts just like jimmalenko said
http://server1.megagames.com/psx/psx_cdr_software.shtml
Basically any software that can do a direct copy of dvd and cd images will do
I know a great installer if you need a modchip
Also sells some ps2s and xboxes from time to time
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 05:35 -
How to get my BluRay HD backups to PS3
By gga in forum Blu-ray RippingReplies: 6Last Post: 13th Feb 2009, 18:43 -
DVDFab and Playstation2 backups
By kdroskinis in forum Newbie / General discussionsReplies: 7Last Post: 9th Aug 2008, 01:24 -
Legal question regarding backups
By ChaunceyK in forum Newbie / General discussionsReplies: 30Last Post: 4th Oct 2007, 09:00 -
The Importance of Backups
By Soopafresh in forum ComputerReplies: 11Last Post: 9th Sep 2007, 18:31
