How do I make a copy of this DVD so that it will work on most DVD players?
Results 1 to 10 of 10
What DVD ?
You have given us absolutely nothing to go with here. What sort of answer do you really expect to get ?
Start again. Give us
1. The movie - source, format etc
2. The guide or process you followed, and any deviations you made along the way.
3. Details of the player it worked with, and the players it didn't
Then, maybe, we can help.Read my blog here.
sorry. i am a first timer if you can't tell. anyway, my buddy gave me a dvd of a new movie. it did not work in my panasonic vcr dvd combo, in my car dvd player but it did work on my Toshiba high end player. I am not sure how to find out the format or source. I copied it to my pc and this is what I see.
METEOR Title 1.mp4 703,436 KB MP4 File
Does this help? If not, could you kindly provide some guidence on how to find additional nessessary information.
Thanks -
That is not a DVD, and the player would have to support that format before it will play it.
There is nothing illegal, until you get caught! -
It does not have that on my car player. I have burned dvds on my sony dvd burner that have worked in my car. is there anyway that i can convert it? without losing quaility? i have nero.
Not with Nero. OK. Let me rephrase that. You can use Nero to convert it, however you will lose quality. The best quality would be to frameserve from avisynth or virtualdub to tmpgenc or CCE or even HC, then author and burn. Keep Nero out of the picture the whole time.
You will have to resize the movie to DVD specs (see my sig for a tool to help you find the correct size), possibly use an unsharp mask to get rid of the softness inherent in resizing up, then encode to the correct bitrate to fit. It's not hard once you've done it a couple of times, and a great learning experience if you want to know what DVD is all about.
Otherwise, you could try VSO DivxtoDVD. The quality should be good, although not as good as doing it all manually. The real advantage it that you don't have to know the ins-and-outs of a duck's arse to do the job.Read my blog here.
sounds great. i will try that. will this be the reason that when i have converted mini dv home vidoe and burned to dvd using nero that the quality sucked? if so, any ideas on that?
Nero's encoder isn't the greatest *cough* understatement *cough*
As a general rule, the best results will always be obtained by using the correct tool for the task, and understanding the process. This may mean you need to learn and understand (there is a difference) several tools and processes, but the outcome will quickly become predictable, and you know that at the end of the process you have a good disk.Read my blog here.
DVD works on DVD player but not recognised in laptop
By rline101 in forum DVD RippingReplies: 6Last Post: 11th Oct 2010, 17:09 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 10:02 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 08:22 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
my dvd-lo that works on Mac, not in external player
By oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 04:22
